Focus I: коды диагностических ошибок с P0100 по P 1000 Ford Focus (тема закрыта)
Ponomarenko_Ivan_Vas
P0100 Mass Air Flow Circuit Malfunction
P0101 Mass Air Flow Circuit Range / Performance? Problem
P0102 MAF Circuit Low Input
P0103 MAF Circuit High Input
P0104 MAF Circuit Intermittent
P0105 MAP/BP Circuit Malfunction
P0106 MAP/BP Sensor Range / Performance? Problem
P0107 MAP/BP Sensor Low Input
P0108 MAP/BP Sensor High Input
P0109 MAP/BP Circuit Intermittent
P0110 IAT Circuit Malfunction
P0111 IAT Circuit Range / Performance? Problem
P0112 IAT Circuit Low Input
P0113 IAT Circuit High Input
P0114 IAT Circuit Intermittent
P0115 ECT Circuit Malfunction
P0116 ECT Circuit Range / Performance? Problem
P0117 ECT Circuit Low Input
P0118 ECT Circuit High Input
P0119 ECT Intermittent
P0120 TP Sensor A Circuit Malfunction
P0121 TP Sensor A Circuit Range / Performance? Problem
P0122 TP Sensor A Circuit Low Input
P0123 TP Sensor A Circuit High Input
P0124 TP Sensor A Circuit Intermittent
P0125 Insufficient Coolant Temp For Closed Loop Fuel Control
P0126 Insufficient Coolant Temp For Stable Operation
P0128 Coolant Thermostat Malfunction
P0130 Heated O2 Sensor Circuit Malfunction (Bank 1, Sensor 1)
P0131 Heated O2 Circuit Low Voltage (Bank 1, Sensor 1)
P0132 Heated O2 Sensor Circuit High Voltage (Bank 1, Sensor 1)
P0133 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 1)
P0134 Heated O2 Sensor Circuit No Activity Detected (Bank 1, Sensor 1)
P0135 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
P0136 Heated O2 Sensor Circuit Malfunction (Bank 1, Sensor 2)
P0137 Heated O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2)
P0138 Heated O2 Sensor Circuit High Voltage (Bank 1, Sensor 2)
P0139 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 2)
P0140 Heated O2 Sensor Circuit No Activity Detected (Bank 1, Sensor 2)
P0141 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
P0142 Heated O2 Sensor Circuit Malfunction (Bank 1, Sensor 3)
P0143 Heated O2 Sensor Circuit Low Voltage (Bank 1, Sensor 3)
P0144 Heated O2 Sensor Circuit High Voltage (Bank 1, Sensor 3)
P0145 Heated O2 Sensor Circuit Slow Response (Bank 1, Sensor 3)
P0146 Heated O2 Sensor Circuit No Activity Detected (Bank 1, Sensor 3)
P0147 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 3)
P0150 Heated O2 Sensor Circuit Malfunction (Bank 2, Sensor 1)
P0151 Heated O2 Sensor Circuit Low Voltage (Bank 2, Sensor 1)
P0152 Heated O2 Sensor Circuit High Voltage (Bank 2, Sensor 1)
P0153 Heated O2 Sensor Circuit Slow Response (Bank 2, Sensor 1)
P0154 Heated O2 Sensor Circuit No Activity Detected (Bank 2, Sensor 1)
P0155 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 1)
P0156 Heated O2 Sensor Circuit Malfunction (Bank 2, Sensor 1)
P0157 Heated O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2)
P0158 Heated O2 Sensor Circuit High Voltage (Bank 2, Sensor 2)
P0159 Heated O2 Sensor Circuit Slow Response (Bank 2, Sensor 2)
P0160 Heated O2 Sensor Circuit No Activity Detected (Bank 2, Sensor 2)
P0161 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 2)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Fault
P0177 Fuel Composition Sensor Circuit Range / Performance?
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range / Performance?
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range / Performance?
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range / Performance?
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0195 Engine Oil Temperature Sensor Circuit Malfunction
P0196 Engine Oil Temperature Sensor Range / Performance?
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction – Cylinder #1
P0202 Injector Circuit Malfunction – Cylinder #2
P0203 Injector Circuit Malfunction – Cylinder #3
P0204 Injector Circuit Malfunction – Cylinder #4
P0205 Injector Circuit Malfunction – Cylinder #5
P0206 Injector Circuit Malfunction – Cylinder #6
P0207 Injector Circuit Malfunction – Cylinder #7
P0208 Injector Circuit Malfunction – Cylinder #8
P0209 Injector Circuit Malfunction – Cylinder #9
P0210 Injector Circuit Malfunction – Cylinder #10
P0211 Injector Circuit Malfunction – Cylinder #11
P0212 Injector Circuit Malfunction – Cylinder #12
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Overtemp Condition
P0219 Engine Overspeed Condition
P0220 Throttle / Pedal? Position Sensor / Switch? B Circuit Malfunction
P0221 Throttle / Pedal? Position Sensor / Switch? B Performance Problem
P0222 Throttle Position Sensor B Circuit Low Input
P0223 Throttle Position Sensor B Circuit High Input
P0224 Throttle Position Sensor B Intermittent
P0225 Throttle Position Sensor C Circuit Malfunction
P0227 Throttle Position Sensor C Circuit Low Input
P0228 Throttle Position Sensor C Circuit High Input
P0229 Throttle Position Sensor C Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Circuit Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range / Performance?
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Wastegate Solenoid A Malfunction
P0244 Wastegate Solenoid A Range / Performance?
P0245 Wastegate Solenoid A Low
P0246 Wastegate Solenoid A High
P0247 Wastegate Solenoid B Malfunction
P0248 Wastegate Solenoid B Range / Performance?
P0249 Wastegate Solenoid B Low
P0250 Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control A Malfunction
P0252 Injection Pump Fuel Metering Control A Range / Performance?
P0253 Injection Pump Fuel Metering Control A Low
P0254 Injection Pump Fuel Metering Control A High
P0255 Injection Pump Fuel Metering Control A Intermittent
P0256 Injection Pump Fuel Metering Control B Malfunction
P0257 Injection Pump Fuel Metering Control B Range / Performance?
P0258 Injection Pump Fuel Metering Control B Low
P0259 Injection Pump Fuel Metering Control B High
P0260 Injection Pump Fuel Metering Control B Intermittent
P0261 Injector Circuit Low – Cylinder #1
P0262 Injector Circuit High – Cylinder #1
P0263 Cylinder #1 Balance Fault
P0264 Injector Circuit Low – Cylinder #2
P0265 Injector Circuit High – Cylinder #2
P0266 Cylinder #2 Balance Fault
P0267 Injector Circuit Low – Cylinder #3
P0268 Injector Circuit High – Cylinder #3
P0269 Cylinder #3 Balance Fault
P0270 Injector Circuit Low – Cylinder #4
P0271 Injector Circuit High – Cylinder #4
P0272 Cylinder #4 Balance Fault
P0273 Injector Circuit Low – Cylinder #5
P0274 Injector Circuit High – Cylinder #5
P0275 Cylinder #5 Balance Fault
P0276 Injector Circuit Low – Cylinder #6
P0277 Injector Circuit High – Cylinder #6
P0278 Cylinder #6 Balance Fault
P0279 Injector Circuit Low – Cylinder #7
P0280 Injector Circuit High – Cylinder #7
P0281 Cylinder #7 Balance Fault
P0282 Injector Circuit Low – Cylinder #8
P0283 Injector Circuit High – Cylinder #8
P0284 Cylinder #8 Balance Fault
P0285 Injector Circuit Low – Cylinder #9
P0286 Injector Circuit High – Cylinder #9
P0287 Cylinder #9 Balance Fault
P0288 Injector Circuit Low – Cylinder #10
P0289 Injector Circuit High – Cylinder #10
P0290 Cylinder #10 Balance Fault
P0291 Injector Circuit Low – Cylinder #11
P0292 Injector Circuit High – Cylinder #11
P0293 Cylinder #11 Balance Fault
P0294 Injector Circuit Low – Cylinder #12
P0295 Injector Circuit High – Cylinder #12
P0296 Cylinder #12 Balance Fault
P0300 Random Misfire Detected
P0301 Cylinder #1 Misfire Detected
P0302 Cylinder #2 Misfire Detected
P0303 Cylinder #3 Misfire Detected
P0304 Cylinder #4 Misfire Detected
P0305 Cylinder #5 Misfire Detected
P0306 Cylinder #6 Misfire Detected
P0307 Cylinder #7 Misfire Detected
P0308 Cylinder #8 Misfire Detected
P0309 Cylinder #9 Misfire Detected
P0310 Cylinder #10 Misfire Detected
P0311 Cylinder #11 Misfire Detected
P0312 Cylinder #12 Misfire Detected
P0320 Ignition Engine Speed Input Circuit Malfunction
P0321 Ignition Engine Speed Input Circuit Range / Performance?
P0322 Ignition Engine Speed Input Circuit No Signal
P0323 Ignition Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range / Performance?
P0327 Knock Sensor 1 Circuit Low Input
P0328 Knock Sensor 1 Circuit High Input
P0329 Knock Sensor 1 Circuit Intermittent
P0330 Knock Sensor 2 Circuit Malfunction
P0331 Knock Sensor 2 Circuit Range / Performance?
P0332 Knock Sensor 2 Circuit Low Input
P0333 Knock Sensor 2 Circuit High Input
P0334 Knock Sensor 2 Circuit Intermittent
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range / Performance?
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary / Secondary Circuit Malfunction
P0351 Ignition Coil Primary A / Secondary Circuit Malfunction
P0352 Ignition Coil Primary B / Secondary Circuit Malfunction
P0353 Ignition Coil Primary C / Secondary Circuit Malfunction
P0354 Ignition Coil Primary D / Secondary Circuit Malfunction
P0355 Ignition Coil Primary E / Secondary Circuit Malfunction
P0356 Ignition Coil Primary F / Secondary Circuit Malfunction
P0357 Ignition Coil Primary G / Secondary Circuit Malfunction
P0358 Ignition Coil Primary H / Secondary Circuit Malfunction
P0359 Ignition Coil Primary I / Secondary Circuit Malfunction
P0360 Ignition Coil Primary J / Secondary Circuit Malfunction
P0361 Ignition Coil Primary K / Secondary Circuit Malfunction
P0362 Ignition Coil Primary L / Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug Circuit A Malfunction
P0381 Glow Plug Indicator Circuit Malfunction
P0382 Glow Plug Circuit B Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range / Performance?
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 EGR Flow Malfunction
P0401 EGR Flow Insufficient Detected
P0402 EGR Flow Excessive Detected
P0403 EGR Circuit Malfunction
P0404 EGR Circuit Range / Performance?
P0405 EGR Sensor A Circuit Low Input
P0406 EGR Sensor A Circuit High Input
P0407 EGR Sensor B Circuit Low Input
P0408 EGR Sensor B Circuit High Input
P0410 SAI System Malfunction
P0411 SAI System Incorrect Upstream Flow Detected
P0412 SAI System Switching Valve A Circuit Malfunction
P0413 SAI System Switching Valve A Circuit Open
P0414 SAI System Switching Valve A Circuit Shorted
P0415 SAI System Switching Valve B Circuit Malfunction
P0416 SAI System Switching Valve B Circuit Open
P0417 SAI System Switching Valve B Circuit Shorted
P0418 SAI System Relay A Circuit Malfunction
P0419 SAI System Relay B Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0426 Catalyst Temperature Sensor Range / Performance? (Bank 1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0436 Catalyst Temperature Sensor Range / Performance? (Bank 2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected
P0443 Evap Emission Control System Purge Control Circuit Malf.
P0444 Evap Emission Control Sys Purge Control Valve Circuit Open
P0445 Evap Emission Control Sys Purge Control Valve Circuit Short
P0446 Evap Emission Control System Vent Malfunction
P0447 Evap Emission Control System Vent Circuit Open
P0448 Evap Emission Control System Vent Circuit Shorted
P0449 Evap Emission Control System Vent Circuit Intermittent
P0450 Evap Emission Control System Pressure Sensor Malfunction
P0451 Evap Emission Control System Pressure Sensor Performance
P0452 Evap Emission Control System Pressure Sensor Low Input
P0453 Evap Emission Control System Pressure Sensor High Input
P0454 Evap Emission Control System Pressure Sensor Intermittent
P0455 Evap Emission Control System Leak Detected (Gross Leak / No? Flow)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range / Performance?
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range / Performance?
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Circuit Malfunction
P0471 Exhaust Pressure Sensor Circuit Range / Performance?
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power / Ground? Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range / Performance?
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent
P0505 Idle Air Control System Malfunction
P0506 Idle Air Control System RPM Lower Than Expected
P0507 Idle Air Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor / Switch? Circuit Malfunction
P0521 Engine Oil Pressure Sensor / Switch? Circuit Range / Performance?
P0522 Engine Oil Pressure Sensor / Switch? Circuit Low Input
P0523 Engine Oil Pressure Sensor / Switch? Circuit High Input
P0530 A / C? Refrigerant Pressure Sensor Circuit Malfunction
P0531 A / C? Refrigerant Pressure Sensor Circuit Range / Performance?
P0532 A / C? Refrigerant Pressure Sensor Circuit Low Input
P0533 A / C? Refrigerant Pressure Sensor Circuit High Input
P0534 A / C? Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range / Performance?
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise ON Signal Malfunction
P0566 Cruise OFF Signal Malfunction
P0567 Cruise RESUME Signal Malfunction
P0568 Cruise SET Signal Malfunction
P0569 Cruise COAST Signal Malfunction
P0570 Cruise ACCEL Signal Malfunction
P0571 Cruise Brake Switch Circuit Malfunction
P0572 Cruise Brake Switch Circuit Low
P0573 Cruise Brake Switch Circuit High
P0600 Serial Communications Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Powertrain Control Module KAM Test Error
P0604 Powertrain Control Module RAM Test Error
P0605 Powertrain Control Module ROM Test Error
P0606 PCM Processor Fault
P0608 PCM VSS Output A Malfunction
P0609 PCM VSS Output B Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp “L” Control Circuit Malfunction
P0622 Generator Field “F” Control Circuit Malfunction
P0650 MIL Control Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range / Performance?
P0702 Transmission Control System Electrical
P0703 Brake Switch Input Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit Malfunction
P0706 Transmission Range Sensor Circuit Range / Performance?
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range / Perf?
P0712 Transmission Fluid Temp Sensor Circuit Low Input
P0713 Transmission Fluid Temp Sensor Circuit High Input
P0714 Transmission Fluid Temp Sensor Circuit Intermittent
P0715 Turbine Speed Sensor Circuit Malfunction
P0716 Turbine Speed Sensor Circuit Range / Performance?
P0717 Turbine Speed Sensor Circuit No Signal
P0718 Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter / Brake? Switch B Circuit Low
P0720 Output Shaft Speed Sensor Circuit Malfunction
P0721 Output Shaft Speed Sensor No Performance
P0722 Output Shaft Speed Sensor No Signal
P0723 Output Shaft Speed Sensor Intermittent
P0724 Torque Converter / Brake? Switch B Circuit High
P0725 Engine Speed Input Circuit Malfunction
P0726 Engine Speed Input Circuit Range / Performance?
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch System Performance Or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch System Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid A Malfunction
P0746 Pressure Control Solenoid A Performance or Stuck Off
P0747 Pressure Control Solenoid A Stuck On
P0748 Pressure Control Solenoid A Electrical
P0749 Pressure Control Solenoid A Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0775 Pressure Control Solenoid B Malfunction
P0776 Pressure Control Solenoid B Performance
P0777 Pressure Control Solenoid B Stuck On
P0778 Pressure Control Solenoid B Electrical
P0779 Pressure Control Solenoid B Intermittent
P0780 Shift Malfunction
P0781 1 – 2 Shift Error
P0782 2 – 3 Shift Error
P0783 3 – 4 Shift Error
P0784 4 – 5 Shift Error
P0785 Shift / Timing? Solenoid Malfunction
P0786 Shift / Timing? Solenoid Range / Performance?
P0787 Shift / Timing? Solenoid Low
P0788 Shift / Timing? Solenoid High
P0789 Shift / Timing? Solenoid Intermittent
P0790 Mode Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1 – 4 Upshift (Skip Shift) Solenoid Circuit Malfunction
P0804 1 – 4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1000 Check of all OBDII Systems Not Complete
Sanal
31.10.13  |
31.10.13 |
to Ilya1974:
P0100 Неисправность в цепи расходомера воздуха
P0101 Неправильный показатель / не отрегулирован расходомер воздуха
P0102 Низкий показатель расходомера воздуха
P0103 Высокий показатель расходомера воздуха
P0104 Неисправность расходомера воздуха
P0105 Неисправность цепи датчика абсолютного давления впускного коллектора / барометрического давления впускного коллектора
P0106 Неправильный показатель / не отрегулирован датчик абсолютного давления впускного коллектора / барометрического давления впускного коллектора
P0107 Низкий показатель датчика абсолютного давления впускного коллектора / барометрического давления впускного коллектора
P0108 Высокий показатель датчика абсолютного давления впускного коллектора / барометрического давления впускного коллектора
P0109 Неисправность датчика абсолютного давления впускного коллектора / барометрического давления впускного коллектора
P0109 Неисправность цепи датчика температуры воздуха на впуске
P0111 Неправильный показатель / не отрегулирован датчик температуры воздуха на впуске
P0112 Низкий показатель датчика температуры воздуха на впуске
P0113 Высокий показатель датчика температуры воздуха на впуске
P0114 Неисправность датчика температуры воздуха на впуске
P0115 Неисправность цепи датчика температуры охлаждающей жидкости двигателя
P0116 Неправильный показатель / не отрегулирован датчик температуры охлаждающей жидкости двигателя
P0117 Низкий показатель датчика температуры охлаждающей жидкости двигателя
P0118 Высокий показатель датчика температуры охлаждающей жидкости двигателя
P0119 Неисправность датчика температуры охлаждающей жидкости двигателя
P0120 Неисправность цепи датчика положения дроссельной заслонки / переключатель А
P0121 Неправильный показатель / не отрегулирован датчик положения дроссельной заслонки / переключатель А
P0122 Низкий показатель датчика положения дроссельной заслонки / переключатель А
P0123 Высокий показатель датчика положения дроссельной заслонки / переключатель А
P0124 Неисправность датчика положения дроссельной заслонки / переключатель А
P0125 Слишком низкая или слишком высокая температура охлаждающей жидкости
P0126 Температура охлаждающей жидкости отличается от нормы
P0130 Неисправность цепи датчика кислорода (bank 1, датчик 1)
P0131 Низкое напряжение цепи датчика кислорода (bank 1, датчик 1)
P0132 Высокое напряжение цепи датчика кислорода (bank 1, датчик 1)
P0133 С опозданием отвечает датчик кислорода (bank 1, датчик 1)
P0134 Не работает датчик кислорода (bank 1, датчик 1)
P0135 Неисправность цепи подогрева датчика кислорода (bank 1, датчик 1)
P0136 Неисправность цепи подогрева датчика кислорода (bank 1, датчик 2)
P0137 Низкое напряжение цепи подогрева датчика кислорода (bank 1, датчик 2)
P0138 Высокое напряжение цепи подогрева датчика кислорода (bank 1, датчик 2)
P0139 С опозданием отвечает цепь подогрева датчик кислорода (bank 1, датчик 2)
P0140 Не работает цепь подогрева датчика кислорода (bank 1, датчик 1)
P0141 Неисправность цепи подогрева датчика кислорода (bank 1, датчик 2)
P0142 Неисправность цепи датчика кислорода (bank 1, датчик 3)
P0143 Низкое напряжение цепи датчика кислорода (bank 1, датчик 3)
P0144 Высокое напряжение цепи датчика кислорода (bank 1, датчик 3)
P0145 С опозданием отвечает датчик кислорода (bank 1, датчик 3)
P0146 Не работает датчик кислорода (bank 1, датчик 3)
P0147 Неисправность цепи подогрева датчика кислорода (bank 1, датчик 3)
P0150 Неисправность цепи датчика кислорода (bank 2, датчик 1)
P0151 Низкое напряжение цепи датчика кислорода (bank 2, датчик 1)
P0152 Высокое напряжение цепи датчика кислорода (bank 2, датчик 1)
P0153 С опозданием отвечает датчик кислорода (bank 2, датчик 1)
P0154 Не работает датчик кислорода (bank 2, датчик 1)
P0155 Неисправность цепи подогрева датчика кислорода (bank 2, датчик 1)
P0156 Неисправность цепи датчика кислорода (bank 2, датчик 2)
P0157 Низкое напряжение цепи датчика кислорода (bank 2, датчик 2)
P0158 Высокое напряжение цепи датчика кислорода (bank 2, датчик 2)
P0159 С опозданием отвечает датчик кислорода (bank 2, датчик 2)
P0160 Не работает датчик кислорода (bank 2, датчик 2)
P0161 Неисправность цепи датчика кислорода (bank 2, датчик 2)
P0162 Неисправность цепи датчика кислорода (bank 2, датчик 3)
P0163 Низкое напряжение цепи датчика кислорода (bank 2, датчик 3)
P0164 Высокое напряжение цепи датчика кислорода (bank 2, датчик 3)
P0165 С опозданием отвечает датчик кислорода (bank 2, датчик 3)
P0166 Не работает датчик кислорода (bank 2, датчик 3)
P0167 Неисправность цепи подогрева датчика кислорода (bank 2, датчик 3)
P0170 Неправильно сбалансирован состав смеси (bank 1)
P0171 Смесь бедная (bank 1)
P0172 Смесь богатая (bank 1)
P0173 Неправильно сбалансирован состав смеси (bank 2)
P0174 Смесь бедная (bank 2)
P0175 Смесь богатая (bank 2)
P0176 Неисправность в цепи датчика состава смеси
P0177 Неправильный показатель / не отрегулирован датчик состава смеси
P0178 Низкий показатель датчика состава смеси
P0179 Высокий показатель датчика состава смеси
P0180 Неисправность в цепи датчика А температуры топлива
P0181 Неправильный показатель / не отрегулирован датчик А температуры топлива
P0182 Низкий показатель датчика А температуры топлива
P0183 Высокий показатель датчика А температуры топлива
P0184 Неисправность датчика А температуры топлива
P0185 Неисправность в цепи датчика B температуры топлива
P0186 Неправильный показатель / не отрегулирован датчик B температуры топлива
P0187 Низкий показатель датчика B температуры топлива
P0188 Высокий показатель датчика B температуры топлива
P0189 Неисправность датчика B температуры топлива
P0190 Неисправность в цепи датчика температуры топлива
P0191 Неправильный показатель / не отрегулирован датчик температуры топлива
P0192 Низкий показатель датчика температуры топлива
P0193 Высокий показатель датчика температуры топлива
P0194 Неисправность датчика температуры топлива
P0195 Неисправность датчика температуры масла
P0196 Неправильный показатель / не отрегулирован датчик температуры масла
P0197 Низкий показатель датчика температуры масла
P0198 Высокий показатель датчика температуры масла
P0199 Неисправность датчика температуры масла
P0200 Неисправность в цепи форсунки
P0201 Неисправность форсунки - цилиндр 1
P0202 Неисправность форсунки - цилиндр 2
P0203 Неисправность форсунки - цилиндр 3
P0204 Неисправность форсунки - цилиндр 4
P0205 Неисправность форсунки - цилиндр 5
P0206 Неисправность форсунки - цилиндр 6
P0207 Неисправность форсунки - цилиндр 7
P0208 Неисправность форсунки - цилиндр 8
P0209 Неисправность форсунки - цилиндр 9
P0210 Неисправность форсунки - цилиндр 10
P0211 Неисправность форсунки - цилиндр 11
P0212 Неисправность форсунки - цилиндр 12
P0213 Неисправность 1 форсунки при пуске
P0214 Неисправность 2 форсунки при пуске
P0215 Неисправность стопорного клапана двигателя
P0216 Неисправность в цепи регулировки момента зажигания
P0217 Перегрев двигателя
P0218 Перегрев трансмиссии
P0219 Слишком высокие обороты двигателя
P0220 Неисправность в цепи датчика положения дроссельной заслонки/Переключатель B
P0221 Неправильный показатель / не отрегулирован датчик положения дроссельной заслонки/Переключатель B
P0222 Низкий показатель датчика положения дроссельной заслонки/Переключатель B
P0223 Высокий показатель датчика положения дроссельной заслонки/Переключатель B
P0224 Неисправность датчика положения дроссельной заслонки/Переключатель B
P0225 Неисправность в цепи датчика положения дроссельной заслонки/Переключатель С
P0226 Неправильный показатель / не отрегулирован датчик положения дроссельной заслонки/Переключатель C
P0227 Низкий показатель датчика положения дроссельной заслонки/Переключатель C
P0228 Высокий показатель датчика положения дроссельной заслонки/Переключатель C
P0229 Неисправность датчика положения дроссельной заслонки/Переключатель C
P0230 Неисправность в первичной цепи топливного насоса
P0231 Низкий показатель вторичной цепи топливного насоса
P0232 Высокий показатель вторичной цепи топливного насоса
P0233 Неисправность во вторичной цепи топливного насоса
P0234 Перегрузка двигателя
P0235 Неисправность в цепи датчика А турбокомпрессора
P0236 Неправильный показатель / не отрегулирован датчик А турбокомпрессора
P0237 Низкий показатель датчика А турбокомпрессора
P0238 Высокий показатель датчика А турбокомпрессора
P0239 Неисправность датчика B турбокомпрессора
P0240 Неправильный показатель / не отрегулирован датчик B турбокомпрессора
P0241 Низкий показатель датчика B турбокомпрессора
P0242 Высокий показатель датчика B турбокомпрессора
P0243 Неисправность соленоид А турбокомпрессора
P0244 Неправильный показатель / не отрегулирован соленоид А турбокомпрессора
P0245 Низкий показатель соленоида А турбокомпрессора
P0246 Высокий показатель соленоида А турбокомпрессора
P0247 Неисправность соленоида B турбокомпрессора
P0248 Неправильный показатель / не отрегулирован соленоид B турбокомпрессора
P0249 Низкий показатель соленоида B турбокомпрессора
P0250 Высокий показатель соленоида B турбокомпрессора
P0251 Неисправность датчика топлива А насоса форсунки (Кулачок/Ротор/Форсунка)
P0252 Неправильный показатель / не отрегулирован датчик топлива А насоса форсунки (Кулачок/Ротор/Форсунка)
P0253 Низкий показатель датчика топлива А насоса форсунки (Кулачок/Ротор/Форсунка)
P0254 Высокий показатель датчика топлива А насоса форсунки (Кулачок/Ротор/Форсунка)
P0255 Неисправность датчика топлива А насоса форсунки (Кулачок/Ротор/Форсунка)
P0256 Неисправность датчика топлива B насоса форсунки (Кулачок/Ротор/Форсунка)
P0257 Неправильный показатель / не отрегулирован датчик топлива B насоса форсунки (Кулачок/Ротор/Форсунка)
P0258 Низкий показатель датчика топлива B насоса форсунки (Кулачок/Ротор/Форсунка)
P0259 Высокий показатель датчика топлива А насоса форсунки (Кулачок/Ротор/Форсунка)
P0260 Неисправность датчика топлива А насоса форсунки (Кулачок/Ротор/Форсунка)
P0261 Низкий показатель цепи форсунки 1 цилиндра
P0262 Высокий показатель цепи форсунки 1 цилиндра
P0263 Неправильно сбалансирован 1 цилиндр
P0264 Низкий показатель цепи форсунки 2 цилиндра
P0265 Высокий показатель цепи форсунки 2 цилиндра
P0266 Неправильно сбалансирован 2 цилиндр
P0267 Низкий показатель цепи форсунки 3 цилиндра
P0268 Высокий показатель цепи форсунки 3 цилиндра
P0269 Неправильно сбалансирован 3 цилиндр
P0270 Низкий показатель цепи форсунки 4 цилиндра
P0271 Высокий показатель цепи форсунки 4 цилиндра
P0272 Неправильно сбалансирован 4 цилиндр
P0273 Низкий показатель цепи форсунки 5 цилиндра
P0274 Высокий показатель цепи форсунки 5 цилиндра
P0275 Неправильно сбалансирован 5 цилиндр
P0276 Низкий показатель цепи форсунки 6 цилиндра
P0277 Высокий показатель цепи форсунки 6 цилиндра
P0278 Неправильно сбалансирован 6 цилиндр
P0279 Низкий показатель цепи форсунки 7 цилиндра
P0280 Высокий показатель цепи форсунки 7 цилиндра
P0281 Неправильно сбалансирован 7 цилиндр
P0282 Низкий показатель цепи форсунки 8 цилиндра
P0283 Высокий показатель цепи форсунки 8 цилиндра
P0284 Неправильно сбалансирован 8 цилиндр
P0285 Низкий показатель цепи форсунки 9 цилиндра
P0286 Высокий показатель цепи форсунки 9 цилиндра
P0287 Неправильно сбалансирован 9 цилиндр
P0288 Низкий показатель цепи форсунки 10 цилиндра
P0289 Высокий показатель цепи форсунки 10 цилиндра
P0290 Неправильно сбалансирован 10 цилиндр
P0291 Низкий показатель цепи форсунки 11 цилиндра
P0292 Высокий показатель цепи форсунки 11 цилиндра
P0293 Неправильно сбалансирован 11 цилиндр
P0294 Низкий показатель цепи форсунки 12 цилиндра
P0295 Высокий показатель цепи форсунки 12 цилиндра
P0296 Неправильно сбалансирован 12 цилиндр
P0300 Нарушен порядок зажигания цилиндров
P0301 Нарушен порядок зажигания 1 цилиндра
P0302 Нарушен порядок зажигания 2 цилиндра
P0303 Нарушен порядок зажигания 3 цилиндра
P0304 Нарушен порядок зажигания 4 цилиндра
P0305 Нарушен порядок зажигания 5 цилиндра
P0306 Нарушен порядок зажигания 6 цилиндра
P0307 Нарушен порядок зажигания 7 цилиндра
P0308 Нарушен порядок зажигания 8 цилиндра
P0309 Нарушен порядок зажигания 9 цилиндра
P0311 Нарушен порядок зажигания 11 цилиндра
P0312 Нарушен порядок зажигания12 цилиндра
P0320 Неисправность в цепи распределителя зажигания
P0321 Неправильный показатель / не отрегулирован датчик цепи распределителя зажигания
P0322 Нет сигнала от датчика цепи распределителя зажигания
P0323 Неисправность датчика цепи распределителя зажигания
P0325 Неисправность в цепи 1 датчика детонации (bank 1 или датчик)
P0326 Неправильный показатель / не отрегулирован 1 датчик детонации (bank 1 или датчик)
P0327 Низкий показатель 1 датчика детонации (bank 1 или датчик)
P0328 Высокий показатель 1 датчика детонации (bank 1 или датчик)
P0329 Неисправность 1 датчика детонации (bank 1 или датчик)
P0330 Неисправность в цепи 2 датчика детонации (bank 2)
P0331 Неправильный показатель / не отрегулирован 2 датчик детонации (bank 2)
P0332 Низкий показатель 2 датчика детонации (bank 2)
P0333 Высокий показатель 2 датчика детонации (bank 2)
P0334 Неисправность 2 датчика детонации (bank 2)
P0335 Неисправность в цепи датчика А положения коленвала
P0336 Неправильный показатель / не отрегулирован датчик А положения коленвала
P0337 Низкий показатель датчика А положения коленвала
P0338 Высокий показатель датчика А положения коленвала
P0339 Неисправность датчика А положения коленвала
P0340 Неисправность в цепи датчика положения распредвала
P0341 Неправильный показатель / не отрегулирован датчик положения распредвала
P0342 Низкий показатель датчика положения распредвала
P0343 Высокий показатель датчика положения распредвала
P0344 Неисправность датчика положения распредвала
P0350 Неисправность в первичной/вторичной цепи катушки зажигания
P0351 Неисправность в первичной/вторичной цепи катушки зажигания A
P0352 Неисправность в первичной/вторичной цепи катушки зажигания B
P0353 Неисправность в первичной/вторичной цепи катушки зажигания C
P0354 Неисправность в первичной/вторичной цепи катушки зажигания D
P0355 Неисправность в первичной/вторичной цепи катушки зажигания E
P0356 Неисправность в первичной/вторичной цепи катушки зажигания F
P0357 Неисправность в первичной/вторичной цепи катушки зажигания G
P0358 Неисправность в первичной/вторичной цепи катушки зажигания H
P0359 Неисправность в первичной/вторичной цепи катушки зажигания I
P0360 Неисправность в первичной/вторичной цепи катушки зажигания J
P0361 Неисправность в первичной/вторичной цепи катушки зажигания K
P0362 Неисправность в первичной/вторичной цепи катушки зажигания L
P0370 Неисправность сигнала А таймера
P0371 Число импульсов сигнала А таймера выше нормы
P0372 Число импульсов сигнала А таймера ниже нормы
P0373 Нестабильные импульсы сигнала А таймера
P0374 Нет импульсов сигнала А таймера
P0375 Неисправность сигнала B таймера
P0376 Число импульсов сигнала B таймера выше нормы
P0377 Число импульсов сигнала B таймера ниже нормы
P0378 Нестабильные импульсы сигнала B таймера
P0379 Нет импульсов сигнала B таймера
P0380 Неисправность в цепи А подогрева свечи накаливания
P0381 Неисправность в цепи А индикатора подогрева свечи накаливания
P0382 Неисправность в системе рециркуляции выхлопных газов
P0385 Неисправность в цепи датчика B положения коленвала
P0386 Неправильный показатель / не отрегулирован датчик B положения коленвала
P0387 Низкий показатель датчика B положения коленвала
P0388 Высокий показатель датчика B положения коленвала
P0389 Неисправность датчика B положения коленвала
P0400 Неисправность в системе рециркуляции выхлопных газов
P0401 Слишком низкий расход в системе рециркуляции выхлопных газов
P0402 Слишком высокий расход в системе рециркуляции выхлопных газов
P0403 Неисправность в системе рециркуляции выхлопных газов
P0404 Неправильный показатель / не отрегулирован датчик системы рециркуляции выхлопных газов
P0405 Низкий показатель датчика А системы рециркуляции выхлопных газов
P0406 Высокий показатель датчика А системы рециркуляции выхлопных газов
P0407 Низкий показатель датчика B системы рециркуляции выхлопных газов
P0408 Высокий показатель датчика B системы рециркуляции выхлопных газов
P0410 Неисправность впускного коллектора
P0411 Неправильно отрегулирован расход во впускном коллекторе
P0412 Неисправность в цепи клапана А впускного коллектора
P0413 Разомкнута цепь клапана А впускного коллектора
P0414 Короткое заземление в цепи клапана А впускного коллектора
P0415 Неисправность в цепи клапана B впускного коллектора
P0416 Разомкнута цепь клапана B впускного коллектора
P0417 Короткое заземление в цепи клапана B впускного коллектора
P0418 Неисправность в цепи реле А впускного коллектора
P0419 Неисправность в цепи реле B впускного коллектора
P0420 Слишком низкая производительность катализатора (bank 1)
P0421 Слишком низкая производительность катализатора при прогреве (bank 1)
P0422 Слишком низкая производительность катализатора (bank 1)
P0423 Слишком низкая производительность катализатора при прогреве (bank 1)
P0424 Слишком низкая температура катализатора при прогреве (bank 1)
P0430 Слишком низкая производительность катализатора (bank 2)
P0431 Слишком низкая производительность катализатора при прогреве (bank 2)
P0432 Слишком низкая производительность катализатора (bank 2)
P0433 Слишком низкая производительность катализатора при прогреве (bank 2)
P0434 Слишком низкая температура катализатора при прогреве (bank 2)
P0440 Неисправность в системе контроля за отводом паров топлива
P0441 Неправильно отрегулирован расход в системе контроля за отводом паров топлива
P0442 Небольшая утечка в системе контроля за отводом паров топлива
P0443 Неисправность в цепи контрольного клапана системы контроля за отводом паров топлива
P0444 Разомкнута цепь контрольного клапана системы контроля за отводом паров топлива
P0445 Короткое замыкание в цепи контрольного клапана системы контроля за отводом паров топлива
P0446 Неисправность в цепи датчика вентиляции системы контроля за отводом паров топлива
P0447 Разомкнута цепь датчика вентиляции системы контроля за отводом паров топлива
P0448 Короткое замыкание в цепи датчика вентиляции системы контроля за отводом паров топлива
P0449 Неисправность в цепи соленоида системы контроля за отводом паров топлива
P0450 Неисправность датчика давления системы контроля за отводом паров топлива
P0451 Неправильный показатель / не отрегулирован датчик давления системы контроля за отводом паров топлива
P0452 Низкий показатель датчика давления системы контроля за отводом паров топлива
P0453 Высокий показатель датчика давления системы контроля за отводом паров топлива
P0454 Неисправность датчика давления системы контроля за отводом паров топлива
P0455 Значительная утечка в системе контроля за отводом паров топлива
P0460 Неисправность в цепи датчика уровня топлива
P0461 Неправильный показатель / не отрегулирован датчик уровня топлива
P0462 Низкий показатель датчика уровня топлива
P0463 Высокий показатель датчика уровня топлива
P0464 Неисправность датчика уровня топлива
P0465 Неисправность в цепи датчика расхода продувки
P0466 Неправильный показатель / не отрегулирован датчик расхода продувки
P0467 Низкий показатель датчика расхода продувки
P0468 Высокий показатель датчика расхода продувки
P0469 Неисправность датчика расхода продувки
P0470 Неисправность в цепи датчика давления выхлопных газов
P0471 Неправильный показатель / не отрегулирован датчик давления выхлопных газов
P0472 Низкий показатель датчика давления выхлопных газов
P0473 Высокий показатель датчика давления выхлопных газов
P0474 Неисправность датчика давления выхлопных газов
P0475 Неисправность в цепи контрольного клапана давления выхлопных газов
P0476 Неправильный показатель / не отрегулирован контрольный клапан давления выхлопных газов
P0477 Низкий показатель контрольного клапана давления выхлопных газов
P0478 Высокий показатель контрольного клапана давления выхлопных газов
P0479 Неисправность контрольного клапана давления выхлопных газов
P0480 Неисправность в цепи 1 вентилятора
P0481 Неисправность в цепи 2 вентилятора
P0482 Неисправность в цепи 3 вентилятора
P0483 Неисправность вентилятора
P0484 Ток перегрузки в цепи вентилятора
P0485 Неисправность в цепи заземления вентилятора
P0500 Неисправность в цепи датчика скорости
P0501 Неправильный показатель / не отрегулирован датчик скорости
P0502 Низкий показатель датчика скорости
P0503 Высокий или нестабильный показатель датчика скорости
P0505 Неправильно отрегулирован холостой ход
P0506 Обороты холостого хода ниже нормы
P0507 Обороты холостого хода выше нормы
P0510 Неисправность концевика дроссельной заслонки
P0520 Неисправность в цепи датчика давления масла
P0521 Неправильный показатель / не отрегулирован датчик давления масла
P0522 Низкое напряжение датчика давления масла
P0523 Высокое напряжение датчика давления масла
P0530 Неисправность в цепи датчика давления охлаждающей жидкости кондиционера
P0531 Неправильный показатель / не отрегулирован датчик давления охлаждающей жидкости кондиционера
P0532 Низкий показатель датчика давления охлаждающей жидкости кондиционера
P0533 Высокий показатель датчика давления охлаждающей жидкости кондиционера
P0534 Утечка охлаждающей жидкости кондиционера
P0550 Неисправность в цепи датчика давления в гидроусилителе руля
P0551 Неправильный показатель / не отрегулирован датчик давления в гидроусилителе руля
P0552 Низкий показатель датчика давления в гидроусилителе руля
P0553 Высокий показатель датчика давления в гидроусилителе руля
P0554 Неисправность датчика давления в гидроусилителе руля
P0560 Неправильно отрегулировано напряжение системы
P0561 Напряжение системы нестабильно
P0562 Низкое напряжение системы
P0563 Высокое напряжение системы
P0565 Неисправность сигнала включения системы круиз-контроля
P0566 Неисправность сигнала выключения системы круиз-контроля
P0567 Неисправность сигнала продолжения движения системы круиз-контроля
P0568 Неисправность сигнала установки скорости системы круиз-контроля
P0569 Неисправность сигнала торможения системы круиз-контроля
P0570 Неисправность сигнала ускорения системы круиз-контроля
P0571 Неисправность в цепи переключателя торможения A системы круиз-контроля
P0572 Низкий показатель переключателя торможения A системы круиз-контроля
P0573 Высокий показатель переключателя торможения A системы круиз-контроля
P0574 Неисправность системы круиз-контроля
P0575 Неисправность системы круиз-контроля
P0576 Неисправность системы круиз-контроля
P0578 Неисправность системы круиз-контроля
P0579 Неисправность системы круиз-контроля
P0580 Неисправность системы круиз-контроля
P0600 Неисправность при связи с системой
P0601 Память блока управления (ROM)
P0602 Программная ошибка блока управления
P0603 Ошибка в постоянной памяти (KAM) блока управления
P0604 Ошибка в памяти (RAM) блока управления
P0605 Ошибка в памяти (ROM) блока управления
P0606 Неисправность процессора PCM
P0608 Неисправность датчика VSS "A" блока управления
P0609 Неисправность датчика VSS "B" блока управления
P0620 Неисправность в цепи управления генератора
P0621 Неисправность в цепи лампы "L" генератора
P0622 Неисправность в блоке "F" генератора
P0650 Неисправность в цепи индикаторной лампы неисправностей (MIL)
P0654 Неправильно отрегулированы обороты двигателя
P0655 Неисправность в цепи лампы прогрева двигателя
P0656 Неисправность в цепи датчика уровня топлива
P0700 Неисправность в системе контроля трансмиссии
P0701 Неправильно отрегулирована система контроля трансмиссии
P0702 Электрическая система контроля трансмиссии
P0703 Неисправность в цепи датчика B уменьшения крутящего момента при торможении
P0704 Неисправность в цепи датчика сцепления
P0705 Неисправность в цепи датчика трансмиссии (PRNDL)
P0706 Неправильный показатель / не отрегулирован датчик трансмиссии
P0707 Низкий показатель датчика трансмиссии
P0708 Высокий показатель датчика трансмиссии
P0709 Неисправность датчика трансмиссии
P0710 Неисправность в цепи датчика температуры трансмиссионной жидкости
P0711 Неправильный показатель / не отрегулирован датчик температуры трансмиссионной жидкости
P0712 Низкий показатель датчика температуры трансмиссионной жидкости
P0713 Высокий показатель датчика температуры трансмиссионной жидкости
P0714 Неисправность датчика температуры трансмиссионной жидкости
P0715 Неисправность в цепи датчика оборотов турбины
P0716 Неправильный показатель / не отрегулирован датчик оборотов турбины
P0717 Нет сигнала от датчика оборотов турбины
P0718 Неисправность датчика оборотов турбины
P0719 Низкий показатель цепи датчика B уменьшения крутящего момента при торможении
P0720 Неисправность в цепи датчика частоты вращения вала
P0721 Неправильный показатель / не отрегулирован датчик частоты вращения вала
P0722 Нет сигнала от датчика частоты вращения вала
P0723 Неисправность датчика частоты вращения вала
P0724 Высокий показатель цепи датчика B уменьшения крутящего момента при торможении
P0725 Неисправность в цепи датчика оборотов двигателя
P0726 Неправильный показатель / не отрегулирован датчик оборотов двигателя
P0727 Нет сигнала от датчика оборотов двигателя
P0728 Неисправность датчика оборотов двигателя
P0730 Неправильно отрегулирована коробка передач
P0731 Неправильно отрегулирована 1 передача
P0732 Неправильно отрегулирована 2 передача
P0733 Неправильно отрегулирована 3 передача
P0734 Неправильно отрегулирована 4 передача
P0735 Неправильно отрегулирована 5 передача
P0736 Неправильно отрегулирована задняя передача
P0740 Неисправность в цепи муфты сцепления
P0741 Неправильно отрегулирована муфта сцепления
P0742 Повреждена муфта сцепления
P0743 Повреждение электрической цепи муфты сцепления
P0744 Неисправность в цепи муфты сцепления
P0745 Неисправность в цепи соленоида давления
P0746 Неправильно отрегулирован соленоид давления
P0747 Поврежден соленоид давления
P0748 Повреждение электрической цепи соленоида давления
P0749 Неисправность соленоида давления
P0750 Неисправность переключателя А соленоида
P0751 Неправильно отрегулирован переключатель А соленоида
P0752 Повреждение переключателя А соленоида
P0753 Повреждение электрической цепи переключателя А соленоида
P0754 Неисправность переключателя А соленоида
P0755 Неисправность переключателя B соленоида
P0756 Неправильно отрегулирован переключатель B соленоида
P0757 Повреждение переключателя B соленоида
P0758 Повреждение электрической цепи переключателя B соленоида
P0759 Неисправность переключателя B соленоида
P0760 Неисправность переключателя C соленоида
P0761 Неправильно отрегулирован переключатель C соленоида
P0762 Повреждение переключателя C соленоида
P0763 Повреждение электрической цепи переключателя C соленоида
P0764 Неисправность переключателя C соленоида
P0765 Неисправность переключателя D соленоида
P0766 Неправильно отрегулирован переключатель D соленоида
P0767 Повреждение переключателя D соленоида
P0768 Повреждение электрической цепи переключателя D соленоида
P0769 Неисправность переключателя D соленоида
P0770 Неисправность переключателя E соленоида
P0771 Неправильно отрегулирован переключатель E соленоида
P0772 Повреждение переключателя E соленоида
P0773 Повреждение электрической цепи переключателя E соленоида
P0774 Неисправность переключателя E соленоида
P0780 Неисправность переключателя
P0781 Неисправность 1-2 переключателей
P0782 Неисправность 2-3 переключателей
P0783 Неисправность 3-4 переключателей
P0784 Неисправность 4-5 переключателей
P0785 Неисправность соленоида
P0786 Неправильный показатель / не отрегулирован соленоид
P0787 Низкий показатель датчика соленоида
P0788 Высокий показатель датчика соленоида
P0789 Неисправность соленоида
P0790 Неисправность в цепи переключателя в режим normal
P0801 Неисправность в цепи контроля системы Reverse Inhibit
P0803 Неисправность в цепи соленоида переключателя 1-4
P0804 Неисправность в цепи контрольной лампы переключателя 1-4
P1106 Высокое напряжение в цепи датчика абсолютного давления впускного коллектора (MAP)
P1107 Низкое напряжение в цепи датчика абсолютного давления впускного коллектора (MAP)
P1111 Высокое напряжение в цепи датчика температуры воздуха на впуске (IAT)
P1112 Низкое напряжение в цепи датчика температуры воздуха на впуске (IAT)
P1114 Низкое напряжение в цепи датчика температуры охлаждающей жидкости (ECT)
P1115 Высокое напряжение в цепи датчика температуры охлаждающей жидкости (ECT)
P1121 Высокое напряжение в цепи датчика положения дроссельной заслонки (TP)
P1122 Низкое напряжение в цепи датчика положения дроссельной заслонки (TP)
P1133 Датчик 1 HO2S
P1134 Таймер включения датчика HO2S
P1200 Цепь управления форсункой
P1336 Не считывается показатель датчика положения коленвала (CKP)
P1350 Bypass Line Monitor
P1361 Низкое напряжение в цепи контроля зажигания (IC)
P1374 Изменение частоты датчика положения коленвала (CKP)
P1380 Неисправность в системе – невозможно считать данные
P1406 Регулировка датчика системы рециркуляции выхлопных газов (EGR)
P1441 Расход в системе отвода паров топлива (EVAP) только для автомобиля Chevrolet
P1441 Расход в системе отвода паров топлива (EVAP) только для автомобиля Oldsmobile
P1554 Цепь обратной связи с системой круиз-контроля
P1626 Потеря сигнала от топливной системы
P1629 Не поступает сигнал от топливной системы
P1635 Цепь 5 вольт, только для автомобиля Oldsmobile
P1635 Цепь 5 вольт, только для автомобиля Chevrolet
P1639 2 цепь 5 вольт, только для автомобиля Oldsmobile
P1639 2 цепь 5 вольт, только для автомобиля Chevrolet
P1641 Контрольная цепь индикаторной лампы неисправностей (MIL)
P1651 Контрольная цепь 1 реле вентилятора, только для автомобиля Oldsmobile
P1651 Контрольная цепь 1 реле вентилятора, только для автомобиля Chevrolet
P1652 Контрольная цепь 2 реле вентилятора, только для автомобиля Oldsmobile
P1652 Контрольная цепь 2 реле вентилятора, только для автомобиля Chevrolet
P1654 Контрольная цепь реле кондиционера (A/C)
P1655 Контрольная цепь соленоида системы отвода паров топлива (EVAP), только для автомобиля Oldsmobile
P1655 Контрольная цепь соленоида системы отвода паров топлива (EVAP), только для автомобиля Chevrolet
P1662 Цепь системы круиз-контроля
P1663 Контрольная лампа перезарядки
P1671 Контрольная лампа замены масла
P1672 Контрольная лампа низкого уровня масла
P1675 Контрольная цепь соленоида системы отвода паров топлива (EVAP)
Список наиболее употребительных сокращений по OBDII
AFC – Расходомер воздуха
ALDL – Диагностический коннектор. Так раньше назывался диагностический коннектор для автомобилей GM, а также разъем для подключения сканнера; также может использоваться как название любых сигналов OBD II
CAN - Контроллер
CARB – Калифорнийский совет по атмосферным ресурсам
CFI – центральный впрыск топлива (TBI)
CFI – непрерывный впрыск топлива
CO – монооксид углерода
DLC – Диагностический коннектор
Driving Cycle – Последовательность пуска, прогрева и движения автомобиля, в ходе этого цикла происходит тестирование всех функций OBD II
DTC – Код неисправности
ECM – Блок управления двигателем
EEC – Электронное управление двигателем
EEPROM or E2PROM – Программируемая память, доступная только для чтения
EFI – электронный впрыск топлива
EGR - рециркуляция выхлопных газов
EMR – электронный блок уменьшения угла зажигания
EPA – Совет по охране окружающей среды
ESC – Электронная регулировка зажигания
EST – Электронная регулировка момента зажигания
Fuel Trim – балансировка состава смеси
HC - углеводород
HEI - зажигание
HO2S – подогрев датчика кислорода
ISO 9141 – международный стандарт для разъема OBDII
J1850PWM – протокол для разъема OBD II, установленный по стандарту SAE
J1850VPW - протокол для разъема OBD II, установленный по стандарту SAE
J1962 – стандарт для диагностического коннектора OBD II, установленный по стандарту SAE
J1978 – стандарт SAE для сканнеров OBD II
J1979 – стандарт SAE для режимов диагностики
J2012 – стандарт SAE, одобренный EPA, для сообщений при тестировании системы выхлопных газов
MAF – расход воздуха
MAP – абсолютное давление во впускном коллекторе
MAT – температура воздуха во впускном коллекторе
MIL – индикаторная лампа неисправностей. Лампа "Check Engine Light" на панели приборов.
NOx – оксид азота
O2 - кислород
OBD - диагностика
OBDII or OBD II – усовершенствованный стандарт для диагностики автомобилей в США после 1-1-96
Parameters – Параметры по диагностике OBD II
PCM – Блок управления трансмиссией
PCV - Картер
Proprietary Readings – Параметры бортового компьютера, которые не требуются для диагностики OBD II, но могут использоваться для диагностики неисправностей различных типов автомобилей.
PTC – Код неисправности
RPM – об/мин
Scan Tool - сканер
SES – лампа сервисного обслуживания двигателя на панели приборов
SFI – последовательный впрыск топлива
Stoichiometric ( Stoy'-kee-o-metric) Ratio – Коэффициент сгорания топлива
TPS – Датчик положения дроссельной заслонки
VAC - вакуум
VCM – центральный блок управления автомобиля
VIN – идентификационный номер автомобиля
VSS – датчик скорости
WOT – открытая дроссельная заслонка
Перевод старых кодов в новые осуществляется по схеме:
0xyz = P0xyz;
1xyz = P1xyz;
2xyz = P2xyz;
3xyz = P3xyz;
4xyz = С0xyz;
5xyz = C1xyz;
6xyz = С2xyz;
7xyz = С3xyz;
8xyz = В0xyz;
9xyz = B1xyz;
Axyz = B2xyz;
Вxyz = В3xyz;
Сxyz = U0xyz;
Dxyz = U1xyz;
Еxyz = U2xyz;
Fxyz = U3xyz;
Sanal
31.10.13  |
31.10.13 |
P1133 Датчик 1 HO2S
CAN - Контроллер
HC - углеводород
HEI - зажигание
NOx – оксид азота
O2 - кислород
OBD - диагностика
PCV - Картер
RPM – об/мин
Scan Tool - сканер
VAC - вакуум
0xyz = P0xyz;
1xyz = P1xyz;
2xyz = P2xyz;
3xyz = P3xyz;
4xyz = С0xyz;
5xyz = C1xyz;
6xyz = С2xyz;
7xyz = С3xyz;
8xyz = В0xyz;
9xyz = B1xyz;
Axyz = B2xyz;
Вxyz = В3xyz;
Сxyz = U0xyz;
Dxyz = U1xyz;
Еxyz = U2xyz;
Fxyz = U3xyz;
Тема закрыта
